I was logging today and noticed the AFR go lean when accelerating for a brief moment. In the olden days of carbs, the accelerator pump took care of this. What in the PCM handles the chore? PE vs RPM?
Not sure if there is a direct match in efilive. But you can have a look at the throttle follower settings. Bump them up a bit.
Are you running with or without a MAF? You might find SD mode better suited for throttle response.
2014 VF SV LS3 Maloo.
At this point in time, with the MAF. I'll go back to SD and see what happens.Originally Posted by ringram
