Results 1 to 4 of 4
Thread: Getting Scanner to read Lambda
    Dec 2007
    Default Getting Scanner to read Lambda
    Hey guys. My brain hurts a little and need help. I have a feeling I am just overlooking something. I want to view my LM-2 as lambda on the scanner. It is going into my Ext.1 and is working properly when I choose WB02-LC11. I just cant seem to figure out the custom PID portion of everything. I want to log in lambda because now that I changed Stoich AFR in the tune to 14.27 for the wonderful E10 we have, now my BEN factor is way off cause commanded AFR is 14.27 which = 1 lambda. I am a fan of tuning with lambda vs AFR.
    And then my next question, this system will only show me Commanded EQ or Commanded AFR, no Commanded Lambda. So what do I need to do, or what formula/custom PID do I need to convert either the commanded AFR or the commanded EQ over to lambda so I can use a BEN Factor for tuning.
    this is a 05 5.3l
    Any help would be greatly appreciated! Thanks Guys
    Lifetime Member darcy's Avatar
    Feb 2012
    How is your LM-2 hooked up? I presume via serial, since you refer to EXT.
    In this case, log Commanded EQRatio (GM.EQRATIO) and Wideband Lambda (EXT.W02LAM1), then use the BEN factor CALC.W02BEN.
    Serial comms from wideband would allow you to log in Lambda.
    PCM commands in EQR.
    Both are independent of stoich AFR.
    ( to run correctly, you would still need to set B3601 to the stoich of the fuel you're running )
  1. lambda instead of afr
    By Webbs in forum External A/D inputs
    Last Post: January 31st, 2014, 09:55 AM
  2. Want to change from a/f to lambda
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 16th, 2011, 01:08 AM
  3. lambda vs a/f
    Last Post: September 22nd, 2009, 09:12 AM
  4. Lambda
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2006, 02:42 PM
  5. Read posts in search...read tut..LM1 help.
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2006, 01:00 PM
Tags for this Thread
