Results 1 to 6 of 6
Thread: Getting Scanner to read Lambda
    Dec 2007
    Default Getting Scanner to read Lambda
    Hey guys. My brain hurts a little and need help. I have a feeling I am just overlooking something. I want to view my LM-2 as lambda on the scanner. It is going into my Ext.1 and is working properly when I choose WB02-LC11. I just cant seem to figure out the custom PID portion of everything. I want to log in lambda because now that I changed Stoich AFR in the tune to 14.27 for the wonderful E10 we have, now my BEN factor is way off cause commanded AFR is 14.27 which = 1 lambda. I am a fan of tuning with lambda vs AFR.
    And then my next question, this system will only show me Commanded EQ or Commanded AFR, no Commanded Lambda. So what do I need to do, or what formula/custom PID do I need to convert either the commanded AFR or the commanded EQ over to lambda so I can use a BEN Factor for tuning.
    This is a 05 5.3l by the way
    Any help would be greatly appreciated! Thanks Guys
    I posted this in another section cause Im not sure which one will get more hits.
    Your calc pid would calculate lambda like this: {CALC.AFR_LC11}/14.7
    The correction factor using commanded EQR is calculated like this: {GM.EQIVRATIO}*{CALC.AFR_LC11}/14.7
    If you have an LM-2 you should try to get serial comms working.
    More info: see post #1 of the Calc.VET thread
    Dec 2007
    Thank you joecar. I had to order the serial out cable for the lm2 so I will make my own cable when it shows up. I have a buddy that does phone stuff so we will make a direct plug and play cable seeing how taq doesn't any more. I found a link a long time ago explaining how to do custom pids in the txt file but I can't find it any more. Would you happen to have a link explaining it all?
    It is fairly easy to make a cable.
    The calc_pids.txt file in post #1 of the Calc.VET thread is probably the easiest lesson on calc_pids...
    ( that calc_pids.txt file is already setup for getting serial comms lambda from wideband )
    but, I'll see if I can locate the thread on calc pids.
    Dec 2007
    Thanks! I already saved the calc_pids.txt the other day so i've got that set. Just wanted more info incase I want to make my own in the future. Just want to know the do's and don't. I got a custom pid to show up on the scan tool but it wouldn't log on the data page so I'd like to find out what I did wrong. Thanks again joecar.
    It did not show up on the Data page...? Post a screenshot of the PIDs tab and Data tab.
  1. Getting Scanner to read Lambda
    By fxracer20v in forum Petrol / Gas
    Last Post: March 25th, 2014, 03:56 PM
  2. lambda instead of afr
    By Webbs in forum External A/D inputs
    Last Post: January 31st, 2014, 10:55 AM
  3. lambda vs a/f
    Last Post: September 22nd, 2009, 10:12 AM
  4. Lambda
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2006, 03:42 PM
  5. Read posts in search...read tut..LM1 help.
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2006, 02:00 PM
Tags for this Thread
