Results 1 to 2 of 2
Thread: weird fuel issue after 3rd gear , engine dies down and seems to hit a rev limiter
    Mar 2014
    Default weird fuel issue after 3rd gear , engine dies down and seems to hit a rev limiter
    Hi guys. this is my first post on here , I am having some issues with my 2011 lml, here is the stats,
    2011 chev 2500 hd lml, autocal dpf egr and urea delete tuner, flo pro 4'' down pipe back stainless exhaust with muffler, 3'' mbrp turbo downpipe, k&n cold air intake, fass titanium 150 gph lift pump system, nicktane cat spin on fuel filter adapter.
    the issue, I was having and shudder with the truck when it was shifting from 5-6 during the shift then it locked up and pulled strong the rest of the way, almost indicating a torque converter shudder, lately it is doing this in the 3-4 shift. 4-5 and 5-6, it only does it on the race tune, the sport econ tune 120 hp tune pulls great, in the race tune while it is shuddering if you let off the throttle and roll back on it very quickly it takes the throttle and pulls strong until the next shift.
    the only issue is with the 150 hp race tune.
    now I never really had an issue until I noticed a small transmission fluid leak and sent it to the dealer for them to repair the leak under warranty, anyways I never thought of checking the fluid level and 900 km after I got it back it was shifting a little erratic and I check the tranny fluid and found I had to add 3.5 liters , hasn't lost any fluid since so it appears the dealer forgot to add any fluid back,
    can this Allison if it detects a slipping condition defuel this much that it causes this shudder, on our snap on scan tool the rail pressure isn't dropping .
    Nov 2013
    can you log slip on the tcm when recreating this issue?
    Calibrator @ The Roadster Shop
    www.roadstershop.com
  1. Replies: 21
    Last Post: July 7th, 2013, 11:31 AM
  2. Weird problem with Rev Limiter
    By Suhail in forum E37, E38 & E67 PFI ECM's
    Last Post: January 20th, 2013, 01:39 PM
  3. 3rd Gear TCC locking/unlocking issue
    By 1BadAction in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2012, 03:41 AM
  4. rev limiter per gear not limiting
    By ryans1000 in forum General
    Last Post: August 25th, 2010, 04:30 PM
  5. Weird E40 05 Vette rev limiter fix
    By 9secVette in forum Gen IV V8 Specific
    Last Post: August 11th, 2010, 03:07 AM
