Results 1 to 10 of 14
Thread: EFI shift calculator
    Default EFI shift calculator
    Just had my trans built to a level 5. Because I can feel 2-3 and 3-4 shifts It seemed I needed to change some shift points. I'd never tried the caculator so I did. It worked great. The only change to the calculated numbers that I made was to raise the converter unlock by 2 mph. With a cam 33mph was too low. It's terrific not to have to worry about all the relationships when setting shifts. Of course I'm probably the only one who never had tried it. If I'm not I highly recommend it.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Aug 2005
    I've never needed it on mine being a M6 until I did some tuning on a guy's auto awhile back and I was like.. WOW, this is badass.. hahaha
    1992 Turbo LSX Notchback Mustang 275 radial car - under construction
    2008 Sierra 2500HD Duramax
    Joe,
    Whos tranny is it??
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    Where is this shift calculator your talking about?
    Jun 2005
    I've never tried it either... In fact I didn't know it existed lol SO how do I find this feature?
    Hello, my name is Erik and I am a horsepower addict...
    Aug 2005
    Its in the speedometer parameters, it says Transmission shift point adjustment, its by percentage.
    It will adjust all the shift points for tire size/gear ratio changes.
    Sep 2005
    That's what I though, but the way you guys where talking about it I though there might be something I was missing. I have done a ton of changing in my shit points by hand trying to make this small, turboed motor, move this big, heavy truck around as fast as possible.
    I was going to say "Cool, new feature..."
    Quote Originally Posted by Redline Motorsports
    Joe,
    Whos tranny is it??
    Howard
    Howard,
    We have an ace tranny builder here in NC. His name is Rod Cook. You can get a level 5 for what's being paid for a level 3. Plus a 1 year warranty.
    - GM 5 pinion planet assemblies front and rear,
    - 4L65E reaction shell w/bearing, (extreme duty sun shell w/bearing).
    - 4l65E input drum with hardened input shaft.
    - HD 2-4 band and drum
    - GM hardened output shaft.
    - 3-4 HD clutches
    - 13 vane pump kit
    - hardened pump ring and spring
    - HD sprag 29 element
    - Full Transgo kit
    Allison TranSynd trans fluid, gaskets, filters, etc.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    What, it's not a calculator
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  1. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
  2. need help with SPEEDO CALCULATOR
    By Boost in forum General (Diesel)
    Last Post: October 17th, 2007, 01:09 PM
  3. Injector Calculator
    By RacerChris in forum Gen III V8 Specific
    Last Post: April 1st, 2007, 08:34 AM
  4. RPM calculator
    By limited cv8r in forum Gen IV V8 Specific
    Last Post: December 24th, 2006, 05:23 PM
  5. EFI shift calculator
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2006, 03:32 AM
