Results 1 to 10 of 15
Thread: Question about "Optimal Timing Table"
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default Question about "Optimal Timing Table"
    Does this table have any effect on the final timing that is commanded with a LS1B PCM? When logging I have all of a sudden started seeing more timing in the log then is being commanded in the spark table at WOT (as much as 8-10 degrees more). I don't see any tables that would add this much timing and the only table I can find with timing numbers that big is the Optimal Timing Table B5919. Everything I see like the ECT and IAT tables usually subtract timing. This just started recently.
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Dec 2005
    Here is a log showing the added timing in question. At frame 1093, RPM 5573 and Grams/sec .65 log is showing 29.5 degrees of timing. At same axis on the Hi-octane table the commanded timing is 17.4. Where is the extra 12.1 degrees coming from?
    The Optimal Timing table is believed to be used by the PCM for purpose of calculating and comparing various things... I don't know that it is ever commanded, but I don't know enough about it.
    Dec 2005
    Thanks joecar! In the log I posted above, do you have a guess where the extra timing is coming from?
    Good question... post your tune file also.
    Apr 2008
    Looking at your log, your IAT is only 59 degrees so I'd be looking at your adder tables, especially any to do with intake air temp. Without seeing your tune it's hard to say, but it's getting added somewhere. As for the Optimal timing table, I once was curious about it and copied my finished high octane table into it, never noticed a difference, but figured that it was "optimal". To clear though I don't recommend doing it as I'm not sure exactly what it does.
    Dec 2005
    Here is the tune. It's a customer's 2001 Chevy truck stock with a Hypertech programmer installed. Went back a few months and looked at some logs and they all showed within a few degrees of the commanded timing. The last 3 cars I logged showed this kind of error. The only difference is I recently updated.
    Dec 2005
    Guess I found the culprit. The extra timing is coming from B5908 Fuel Mixture Spark Correction. The Hypertech is not leaning the fuel out at WOT like I normally do when tuning with EFIlive. Learn something new everyday!
    Good find, that explains it.
    Junior Member ecir45's Avatar
    Aug 2013
    Thanks for bringing this up, had the same problem. Looks like we can just zero that whole table out.
    '92 K1500 Blazer, L31, NV3500, TPI, 14 bolt 3.42, 0411, EFI Live
    '99 SCSB Stepside Silverado, 5.3, 4L60e, 10 bolt 3.42, 0411, EFI Live
  1. Question about "Optimal Timing Table"
    By 67SS509 in forum Gen III V8 Specific
    Last Post: February 19th, 2015, 04:33 AM
  2. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  3. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
