Results 1 to 4 of 4
Thread: T43 Autocal V2 Licensing Issue and knowledge confirmation.
    May 2009
    Default T43 Autocal V2 Licensing Issue and knowledge confirmation.
    Ok...customer sent me their TCM T43 to be programmed. I used an AutoCal to do so and sent him the TCM back with the AutoCal. It was a few months since the order was fulfilled. He decided to go a different direction and return the TCM for a full wipe clean.
    Problem is, once I read the file in there and look at the Calibration tab I see that the ID and checksums all match, BUT the VIN# and Calibration and BCC Identifier# themselves are different. Additionally, neither the V2 or Autocal are showing as licensed to the TCM.
    Did the initial program never take? I see where a license was used and the tune I loaded into the Autocal in Dec, but upon reading the TCM it's showing the last program date was in November. So I'm at a loss!
    Could I have lost a license somewhere? Did he send me the wrong TCM? Could he have had it reprogrammed with EFILive/HPT/GM Tech Tool and kicked out my license?
    HELP!!
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    The TCM serial number won't get changed on a reflash with any programmer (EFI, TechII, HPT), if the TCM serial number is different to the one you expect then it is not the same TCM.
    Have a look at the file you originally read from that TCM vs what you just read and compare the TCM serial number.
    Eg,
    Serial Number DVQ313719911
    Also, notice the description for the programming date says - Last Programmed by GM, this date code is only written by TechII when it flashes, not EFILive.
    May 2009
    Thanks for the quick response, Ross. Good to know for the future. Problem is, the TCM was sent to me as a "blank" disposable TCM, so I didn't bother to pull the actual original calibration file from it (to compare the serial number). However, I do see that my comments section was wiped out, too. So the main question I guess I need to know (for future reference too) is would the license and/or my comments section be preserved or wiped out in a TechII rewrite?
    The comments aren't actually written back to the controllers, that is just something tagged on the end of the .ctz / .tun file.
    I think you'll find the TCM actually has the serial number stamped on it somewhere.
  1. Not understanding why I would need Autocal to read my T43 in a 2010 Silverado
    By JOHNGEAR in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 13th, 2014, 09:33 AM
  2. dsp5 issue with autocal
    By Landon_Buck in forum Duramax LLY
    Last Post: July 26th, 2013, 04:40 PM
  3. autocal dsp5 issue
    By Landon_Buck in forum General
    Last Post: July 26th, 2013, 04:27 AM
  4. HPT knowledge
    By Doc in forum Lounge
    Last Post: March 16th, 2007, 04:13 PM
