Results 1 to 7 of 7
Thread: Cat over temperature protection question
    Jan 2013
    Default Cat over temperature protection question
    This question is in regards to a 2005 GMC Sierra 5.3L auto.
    Is it the downstream O2 sensors that monitor the temp for the CAT over temperature protection function?
    No.
    O2 sensors do not measure temperature.
    The PCM calculates the catalyst temperature based on fueling, timing, torque, load aand a few other things.
    Jan 2013
    Thanks Joe. I just wanted to be sure that with turning off the rear O2's I didn't cause any issues.
    Turning off the rear O2S will prevent cat efficiency readiness test from running... but PCM will still calculate cat temperature.
    Feb 2014
    If you are disabling the rear O2's does it make sense to disable cat protection in the ECU?
    Jul 2005
    N ot necessarily, if you are removing teh cats, it would make sense to disable the cat protection protocol.
    peace
    Hog
    Feb 2014
    My cats are gone, so I will disable the cat protection maps.
  1. Replies: 6
    Last Post: September 6th, 2010, 03:26 PM
  2. Cat protection
    By Ram Air IV in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2010, 05:12 PM
  3. Cat protection question
    By InTruckDesign in forum E37, E38 & E67 PFI ECM's
    Last Post: July 23rd, 2010, 06:50 AM
  4. E38 PE and Cat Protection Truck question
    By ssvolvo in forum E37, E38 & E67 PFI ECM's
    Last Post: November 12th, 2008, 11:03 AM
  5. Cat Converter Over Temp Protection
    By Biggsy in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2007, 10:43 AM
