Results 1 to 7 of 7
Thread: copying trans segments
    Aug 2013
    Default copying trans segments
    just trying to coy 4l80e trans segments to my cos .due to the fact that they are different os i cant load as alternate comparison.just wondering is there an easy way to do this as i have swapped from 4l60e.
    If you have a 4L80E file with the same OS id as what your COS is based on, then do this:
    - open your GM OS (that your COS is based on) as the calibration,
    - open the 4L80E file as the alternate,
    - do Edit->Copy Entire Segment->Transmission,
    - save the calibration file,
    - full flash the calibration file into PCM,
    - do COS update (full flash the empty COS file, cal flash the calibration file, edit COS tables to sanity).
    Aug 2013
    i cant seam to find an os that seams to match mineits 1290005.ive looked at tunefile depot just wondering if there was any where else to look.
    thanks
    Aug 2010
    Quote Originally Posted by smellyflange View Post
    thanks
    That is because 1290005 is an EFILive COS. It is based on Holden OS 12225074 - which was never offered with a 4L80 - so there is no available 4L80 segment to swap.
    Lifetime Member darcy's Avatar
    Feb 2012
    01290005 is the COS from 12225074.
    This indicates you're working on a Holden.
    Since Holden has never offered a 4L80, there is no matching tune that EFIL can do the trans segment swap with for you.
    You will have to swap to an OS like 12212156 (which came with 4L60E or 4L80E... you will have to copy your tables over, one-by-one).
    Note: always do the segment swap first, and then do the COS upgrade... do not do the other way.
    Aug 2013
    thanks for that
  1. Please help with changing 4L60e Trans segments to 4L80e
    By ttls1 in forum Gen III V8 Specific
    Last Post: April 15th, 2013, 08:31 AM
  2. copying file to v2
    By electricblue in forum FlashScan V2
    Last Post: August 24th, 2011, 08:28 AM
  3. one or more invalid checksum segments
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 16th, 2010, 05:22 AM
  4. E38 w/ No transmission Segments
    By Shupe in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 14th, 2008, 01:32 AM
  5. Fuel Segments for 1998 T/A
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: May 14th, 2008, 05:12 AM
