I just swapped in a 4L80E built by me and Circle D 2800 stall triple disk. The tuning was minimal, its mostly stock 80E settings with the shift speeds adjusted for the 3.42 gears and zeroed out shift times. This is my first auto, never done auto tuning or logging before. The trans settings are basically straight from an 02 Silverado 6.0L tune with some minor tweaks and the shift points changed for my gears. Definitely needs some more work.
1) When I use the DVT to turn on the TCC solenoid I can hear a very faint click, not nearly as loud as the shift solenoids. But when I try to engage the TCC while driving nothing happens. It also seems to have engaged a couple times on its own during the logging and nothing happened. On a couple occasions its tried to engage when letting off heavy throttle. Is that normal?
2) In gears 1-3 the turbine speed is nearly identical to the input speed, and the output speed is the input speed divided by the gear ratio. But in 4th, the input and output speeds are the same (same in 3rd also) but the turbine speed is now equal to the output speed divided by the gear ratio. Is this normal?
3) The TC slip speed seems awfully high, up to 2000 rpm when heavy on the gas, and 600-900 rpm when cruising. Is this normal?
Sorry for the noob questions, this is my first ever data logging of auto PIDs. I've attached the tune and a couple logs.
Thanks!
