Results 1 to 5 of 5
Thread: 2003-2007 Green Blue ECU
    Aug 2011
    Default 2003-2007 Green Blue ECU
    Did any of these ECU's have an EGR? I know EGR was pretty much not used after 2002 but I'm looking to use another input to monitor fuel pressure as I'm currently using the A/C Input for a wideband. So is the EGR input still there on the ECU with a supported PID or Do i need to try using the EVAP input?
    Nov 2006
    C1 (blue) pins 5-10 & 45-50 should all be 5v
    the signal can go to the ad inputs instead of using channels for calc_pids
    LC-1 WBO2
    Aug 2011
    Quote Originally Posted by mr.prick View Post
    I know i can use the ad pins, but im looking to do this into the ECU.
    Aug 2011
    do the grounds group pins like that too?
    Nov 2006
    Default Ls1b 1mb
ID:	16650Click image for larger version.
ID:	16647Click image for larger version.
ID:	16648Click image for larger version.
ID:	16649Click image for larger version.
    LC-1 WBO2
  1. F302 Green Top Injector Specs
    By white01ss in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 05:01 AM
  2. Pros: green horn stuck
    By Gonz in forum E37, E38 & E67 PFI ECM's
    Last Post: March 4th, 2008, 05:03 PM
  3. new dumb and green
    By slowtruck in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2006, 12:28 PM
