Results 1 to 5 of 5
Thread: E78 PE not following my tunes command
    Lifetime Member samh_08's Avatar
    Oct 2008
    Default E78 PE not following my tunes command
    I have a tune and short scan attached below. I can change the PE enablers and values to whatever I want and it seems the ECM just does as it pleases.
    On my LS1 1MB PCM PE kicks in perfectly, every time, to whatever adjustment I want.
    Am I missing something, or is EFILive missing some tables? (I know E78's lack many tables vs E38)
    Is PE enabling...? Look at B0156 and B0157.
    Oct 2008
    B0156 = Throttle Threshold >> Throttle at 100%
    B0157 = Load Threshold >> Should be close to atmosphere (wide open)
    I believe both of these should be met as the vehicle was wide open from 0-100mph, correct?
    edit: In the attatched log it takes 5 seconds to go into what looks like PE, but then it goes richer than the values I have entered in the tune...?
    Jan 2012
    Try to disable cat protection P0804 and zero out p0168 and p0158
    Lifetime Member Boost's Avatar
    Dec 2006
    I got a better one, my tune's commanded PE... CHANGES ITSELF! Too busy to post about it, but I'll get around to it.
    8.7 @ 84 (1/8 mile) bolt-ons
  1. how do you command richer than 9.79 in pe?
    By ls1mike in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2013, 12:25 PM
  2. E38 Throttle command cranking?
    By DVR IMP in forum E37, E38 & E67 PFI ECM's
    Last Post: December 2nd, 2011, 05:14 AM
  3. How many MM3's can you command?
    By LBZoom in forum Duramax LB7
    Last Post: February 2nd, 2010, 12:15 PM
  4. What AFR do you want to command at Idle?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:06 PM
  5. command vs actual a/f
    Last Post: June 9th, 2006, 01:50 AM
