Hey guys, been working on an H1 Alpha Hummer with a Duramax in it. Its a 2006 LLY, but has the older Delphi LLY ECM in it. I read the stock tune out and attempted to modify it with a DSP5. Everything flashed ok but when I took it out to drive it the DSP tunes would have a dead pedal. The main tune ran just fine. So, I decided to try a 15231600 OS out of a 2005 2500HD since it was the same OS as the Hummer. It also flashed ok and all my tunes ran just fine. Then came another issue, I had no Coolant or Trans temp gauge and no oil pressure gauge. The one and only difference in the 2 OS's is that the segments are definitely different between the 2. Has anyone else ran into this? The customer isnt really concerned but I want to make this DSP5 capable. Here is the stock tune out of the Hummer JustinMasterson_H1AlphaHummer_stock_tune.tun
