Results 1 to 9 of 9
Thread: L92 on LS1B 00' PCM, posted in both sections not sure where it belongs lol
    Oct 2011
    Default L92 on LS1B 00' PCM, posted in both sections not sure where it belongs lol
    I've got a customers car in for a cam swap, its a 97 LT car with a LS1B 00' PCM in it, and a L92 from an Escalade. Someone already had deleted VVT and the car runs but not correctly fueling wise. When I went to tune the car I noticed that fueling adjustments were doing nothing. I have the car forced into Open Loop as well as Speed Density Mode for the time. DFCO is off as well, I realized that the PCM is running off the backup VE table. First thing I thought is what's going on with the reluctor setups? I know the L92 is 58x crank and 4x cam and the PCM will only read 24x/1x. But I assume if this was wrong before the car wouldn't even run? Would it? This is a new one for me.....any info would be greatly appreciated. I've tuned boat loads of these cars in SD and MAF and have never seen one run off the backup VE table. What causes the PCM to even look at that table?
    Thanks!!
    Mike
    Lifetime Member darcy's Avatar
    Feb 2012
    Post a copy of your tune for the most assistance.
    If you want to stick with the stock OS then you need to make changes to the backup VE, that's just the way '98-'00 OSs work.
    Otherwise update to a later year COS, say 02020005 as it gives lots of stock base files that can be used to start with, and not worry about Main/Backup VE.
    As for reluctors, it must be right or it wouldnt run, as you said. It's either had a reluctor change or is running a converter box.
    Like Darcy said, you will need to copy/interpolate/extrapolate the injector tables (all of them).
    Also your MAF table needs to be corrected for your actual MAF/plumbing.
    And you need VE and Backup VE tables that match the engine.
    ( in SD mode (i.e MAF is failed) the PCM uses the Backup VE table, so you have to edit both )
    Aug 2010
    I realize you did not do this conversion ...
    Not sure who would go to all the bother involved, to then use a 2000 model year OS ... doesn't make much sense.
    Check that the engine has been fitted with Gen III knock sensors, and that these are properly wired. If not, the engine will have absolutely zero knock protection - not good.
    +1 what Taz said.
    Replace OS with 12212156 with the following matching your actual hardware:
    - transmission segment (4L60E, 4L80E, manual),
    - transmission diagnostic segment),
    - throttle control (DBW, DBC).
    Oct 2011
    just a quick reply on this, I did get the car straightened out, I re-flashed the pcm to the 12212156 OS after realizing it was a 2000 cal, tuned speed density closed loop and it ran great even with the big cam, I appreciate the responses guys!!! thanks!!!
    Quote Originally Posted by quik95lt1 View Post
    how did you get the 58X crank engine to run on the 24X ecm?? am i missing something?
    Rob
    Just one guy tryin' to make a difference
    Quote Originally Posted by v8vegaman View Post
    Rob
    Probably a LPE converter box, easiest way Im aware of currently.
    v8vegaman,
    The converter mentioned by darcy is the LPE 58x/4x -> 24x/1x converter mentioned by Erik.
    Or, as darcy mentioned, the L92 may have been fitted with a 24x CKP reluctor and a 1x CMP sprocket.
    Quote Originally Posted by darcy View Post
  1. L92 on LS1B 00' PCM in backup mode????
    By quik95lt1 in forum Gen III V8 Specific
    Last Post: April 5th, 2014, 03:11 AM
  2. do you need an LS1B PCM ?
    By Boost in forum Gen III V8 Specific
    Last Post: February 19th, 2013, 09:39 AM
  3. LY6 E38 PCM to LS1B PCM convertion?
    By trimchip in forum General (Petrol, Gas, Ethanol)
    Last Post: July 14th, 2012, 05:25 PM
  4. Replies: 3
    Last Post: August 24th, 2010, 03:53 AM
  5. Local sections?
    By Stangkiller in forum Lounge
    Last Post: September 18th, 2006, 01:47 AM
