Results 1 to 3 of 3
Thread: Flaring Issue in 2nd gear
    Sep 2013
    Default Flaring Issue in 2nd gear
    Forgive me if this isn't clear and concise, as I'm relatively new to this. I have a 6L80E in a 2011 Camaro SS that has been modded, and tuned with EFILive. The transmission shifts fine when I launch at the drag strip from 1st gear in Sport Mode, however when I launch from M2 the transmission flares badly and hits the rev limiter before it shifts. The TCM is programmed to auto shift at WOT from M2. If you're wondering why I would launch from 2nd it's because I'm trying to slow the car down to where it runs higher than 12 seconds in the 1/4, so I can pass tech (no roll bar) for bracket racing. I do use a professional tuner and he seems to be baffled by this, but I dabble at changing shift points and other easy, simple stuff. Thanks for any thoughts.
    Sep 2013
    Thanks joecar, I think you nailed the issue. I have been logging GM.TRQENG_C in all my logs and it is definitely lower on the M2 logs than the Sport Mode logs. The calculated torque is down in the 500 area on the M2 logs and in the upper 800 area in the Sport Mode logs. I'm just not smart enough to figure out why and correct it. The fact that I have an L99 converted to an LS3 without a VVT cam is helping to confuse me. I just don't understand how these calculated torque values can be different in the two logs when the ECM and TCM tunes haven't changed. Newb brain freeze?
  1. Upshift to 2nd gear when in maual 1st-4L80E
    By mysunnshine in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 17th, 2015, 03:12 PM
  2. A6 flaring??
    By alian in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 27th, 2010, 08:01 AM
  3. Why does 1st gear slam into 2nd? 4L80E translplant
    By 1SlowHoe in forum Gen III V8 Specific
    Last Post: May 22nd, 2010, 08:47 AM
  4. Locking converter in 2nd gear...
    By LS1_Dragster in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2009, 10:38 PM
  5. 4L80E 2nd & 3rd gear only
    By rickwils51 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 1st, 2007, 05:06 AM
