Results 1 to 10 of 15
Thread: What to scan
    Default What to scan
    Figured some folks might want some guidence with this one.
    First thing, open up the text file in notepad for reference -
    "My Documents\EFILive\V7\User Configuration\cal_link.txt"
    This file links the scanned data with the tables in the editor.
    The tables in the editor can only be tracked with scanned data if the scan PID has been logged and is defined in this file (which you can edit).
    So first up what are the typical things you need to log when tuning.
    For myself this is my PID selection -
    SAE.RPM - SAE Defined Engine RPM
    SAE.MAP - SAE Defined Manifold Pressure
    SAE.ECT - SAE Defined Engine Coolant Temp
    SAE.VSS - SAE Defined Vehicle Speed
    SAE.IAT - SAE Defined Engine Intake Air Temp
    SAE.TP - SAE Defined Throttle Position
    SAE.SPARKADV - SAE Defined Final Ignition Timing
    GM.KR - GM Defined Spark Retard due to knock
    GM.AFR - GM Defined Commanded Air/Fuel Ratio
    GM.EQIVRATIO - GM Defined PID for commanded Fuel EQ Ratio
    GM.CYLAIR_DMA - EFILive PID for MAF Air Flow in g/cyl
    OR
    GM.DYNCYLAIR_DMA - EFILive PID for MAP Air Flow in g/cyl if MAFless
    GM.IAC - GM Defined PID for IAC Steps
    GM.ASPARK - GM Defined PID for High/Low octane scaler percentage
    GM.GEAR - GM Defined current transmission gear
    EXT.AD1 - For WBO2 Logging
    This takes up 20 PID channels, I ALWAYS try to keep the number under 24 due to the fact under 24 gives faster scan speeds.
    So that leaves 4 spare PID slots to add in other PID's that might be specific to something you are trying to monitor.
    Now, that set of PID's is very good for linking back scanned data into the editor as it pretty much covers all tables that are based on g/cyl and MAP kPa and of course RPM.
    Try logging this set of PID's then opening up your .tun file and look in the tables that are defined in the cal_link.txt file.
    You should see the cell highlighted that matches the scanned data values the cursor is at.
    Look at the screen shot to see how the scanned data is linked into the VE table on this example (see the purple cell at 4400RPM and 100kPa in the table), that is the cell the PCM was using at this point in the log file.
    Fire away with further questions.....
    Oct 2003
    Thanks Ross! Can't wait to try it! How easy can this get??
    joel
    Dec 2004
    Thanks Ross!
    Boy, I was wondering what I did 'wrong' in the VE table when I saw the highlighted purple cell. I was chasing a knock problem that I had scanned... the problem area was staring me right at my face.
    Does it also highlight the Spark table cells, too? EDIT: Just noticed your comment, below: :wink:
    Cheers
    Mar 2005
    Sorry to drag up an old thread but I can get this to work with a dashboard layout like in the example but when I try to use a map (KR data with MAP kPA and RPM as X and Y) it doesn't highlight the cell in the Tune Tool.
    Any suggestions or is this by design?
    Quote Originally Posted by jsttry
    Are you trying to highlight cells in a map in the scan tool and expect the corresponding cells in the tuning tool to be highlighted?
    That won't work.
    What you can do, is highlight the entire* chart range that contains knock and ALL the cells in the tuning tool calibration tables will be highlighted. Assuming the link-PIDs are configured in cal_link.txt
    *data linking betwen the Scan and Tune Tools is limited to the first 100 selected frames.
    Mar 2005
    That won't work.
    Yep that is what I was trying to do. I normally use the MAP in the scan tool as you can set it up to look exactly like the VE table in the tune tool. Will have a play with the charts and see if it makes things easier.
    Feb 2006
    This should be made into a sticky! This really helped me get started.
    Mahalo
    KARR
    '01 Chevy S10 4.3-4L60E:
    ΒΌ w/juice: 13.893 @ 98.24mph
    Right Click and Save as:Last run @ Hawaii Raceway Park Video
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    I didnt't find the 'cal-link.txt' file in "My Documents\EFILive\V7\User Configuration", but found it in "C:\Program Files\EFILive\V7\Configuration".
    I am using the latest download from January 30, 2006. Was the 'cal_link.txt' moved on this release or do I have something wrong ?
    Hmmm... I have that file in both locations...
    Sep 2003
    Are the 'Date Modified' dates and 'Size' for both the same ?
  1. Can't Scan
    By Follmer in forum Duramax LB7
    Last Post: May 10th, 2010, 07:38 AM
  2. MAF Hz on an Lt1 96 Scan
    By Highlander in forum Vortec V6/V8 Specific
    Last Post: March 25th, 2010, 06:50 PM
  3. scan obd 2
    By 69camaro5speed in forum General
    Last Post: March 29th, 2007, 03:10 PM
  4. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 03:41 AM
  5. can i scan any gm car?
    By ZL1Killa in forum General
    Last Post: October 8th, 2005, 08:54 PM
