Results 1 to 4 of 4
Thread: Things to log on the LLY
    Lifetime Member bobo's Avatar
    Nov 2005
    Default Things to log on the LLY
    Here are some of the PID's I use for logging the LLY:
    Y Actual Fuel Rail Pressure GM.FRPACT
    Y Air Flow Rate From Mass Air SAE.MAF
    Y Barometric Pressure GM.BARO2
    Y Actual Boost Pressue CALC.ACTBOOST
    Y Desired Fuel Rail Pressure GM.FRPDES
    Y Engine Coolant Temperature SAE.ECT
    Y Engine RPM SAE.RPM
    Y Intake Air Temperature SAE.IAT
    Y Main Injection Fuel Flow R GM.MAINRATE
    Y Main Injection On Time GM.MAINBPW
    Y Main Injection Timing GM.MNINJTIM
    Y Pilot Injection Fuel Flow Ra GM.PILOTRATE
    Y Pilot Injection On Time GM.PILOTBPW
    Y Pilot Injection Timing GM.PIINJTIM
    Y Throttle Position TP GM.TP
    Y Throttle Base Fuel Flow Rate GM.FUELQ_THR_DMA
    Y Vehicle Speed Sensor SAE.VSS
    Y Turbo Boost Pressure GM.BOOST_DMA
    Y Turbo Vane Position GM.TCVPOS
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Dec 2005
    BobO
    Thanks for the info..
    Keep up the good work
    New Member 04llygmc's Avatar
    Thanks Bobo
    04.5 lly
    efi live Thanks Trippin
    4 inch cat back
    air raid cai
    Thanks Bobo!
  1. Replies: 5
    Last Post: August 7th, 2006, 02:44 PM
  2. Things you need to start tuning
    By bobo in forum General (Diesel)
    Last Post: March 8th, 2006, 08:17 AM
