Yes, same as you've been doing, same start up log... same pids. I altered your startup spark as well, so I want to see if it's more inclined to start now.
I'm sanity checking on the procedure...
sac811,
are you using wideband only (I see trims/CL disabled in the log)...?
if so, what pid are you using to correct the VE table (CALC.WO2BEN)...?
Just sanity checking
( if you use CALC.SELBEN, this will have flat 1.00 spots from LTFT's being zero due to trims/CL being disabled, and this will mislead your efforts )
3 cold start attempts this morning (they didn't want to act right as the same file for some reason):
LS1B_0455.efi
LS1B_0456.efi
LS1B_0457.efi
The last is it running for a bit after throttle aid start.
This is a successful start without throttle aid at 40C and the ride home afterwards:
LS1B_0461.efi
Mind you, the cold starts in the previous thread were without proper rafig/rafpn for that cold of a start, since the temperature just went from 80 degrees F yesterday to 40 degrees F this morning...hate these weather changes up and down in Louisiana.
Unaided start at 40C is good. You will need to redo your RAFIG/RAFPN for those colder temperatures.
Okay, here's Mod4. A few changes in this one. I think you'll see a good improvement with these changes.
