Thread: $538 code trying to read tune
    Default $538 code trying to read tune
    Got autocal from motorops last week. Installed dsp5 and tunes last night. Seams my dsp switch isn't working so I go to data section I believe to read voltages of switch. Got a code also so I go to read tune and another code. Truck runs fine with dpf removed, or so it seams to so far. What can I do or what can I do?
    08 lmm 3500hd
    Using Tapatalk
    Nov 2005
    The error you have is $0538, which means the controller contains a DSP Operating System which can't be read.
    You cannot read out a DSP file because the file is written to non readable memory of the ECM.
    Cindy
    The Green light on the back never lit for me either. When I hooked it up it flashed red real fast then I tried the button again and nothing won't light up. Never seen green
    Using Tapatalk
    Nov 2005
    There are no lights on the back of AutoCal. There are 3 buttons on AutoCal, you will need to be more specific as to which one you refer to. When you pressed the button what were you trying to do? Be very specific with detailing menu selections. Were you connected to the vehicle? Were you connected to a PC? What position was your ignition on?
    Have you contacted Motorops? They are the people who configured AutoCal for your vehicle and are your first contact point for support.
    Cindy
    After instalation of dsp5 switch you push the button
    Using Tapatalk
    Nov 2005
    What button? The button on the physical switch? Or an AutoCal button. NOTE: AutoCal has 3 buttons, if you mean AutoCal, you need to specify which button, and also explain the task you are trying to perform by pressing that button. For reference, a picture of AutoCal can be found on our website on the right hand side below FlashScan. http://www.efilive.com.
    Can you also please review my previous post and answer each of those questions too.
    Cindy
  1. Replies: 8
    Last Post: April 9th, 2013, 01:00 PM
  2. 6.7 Read error code
    By JeromeGTO5.7 in forum Cummins 6.7L
    Last Post: December 1st, 2012, 02:28 PM
  3. can someone read this tune
    By c2500dmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 28th, 2011, 10:06 AM
  4. SD Tune and the P0102 code
    By Johnnydangerously in forum General (Petrol, Gas, Ethanol)
    Last Post: October 15th, 2008, 04:42 PM
  5. '09.5' G8 tune...can't read?
    By hquick in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 05:05 AM
