Results 1 to 5 of 5
Thread: How to export and tune a E55 flash only supported ecu.
    Jan 2014
    Default How to export and tune a E55 flash only supported ecu.
    Hello
    Im new to autocal/flashscan.
    Our dealer have read with autocal, a E55 ecu, wich is flash only supported.
    He have sent the readout to me, (saved from the scan and tune sw), because it didnt show up in the efilive explorer as a read file.
    The filename of the read file was E55.ctz and file size is 933kb.
    I have 2 questions.
    1. How can i export a file , so i can modify it in any other external editing software, and how do i import the file again before saving it for my customers autocal.
    2. When i modify the file in any other software, do i need to do a checksum correction on the file?
    Thanks.
    Aug 2010
    Quote Originally Posted by frankis78 View Post
    1. How can i export a file , so i can modify it in any other external editing software, and how do i import the file again before saving it for my customers autocal?
    You can't ....
    You are asking how to hack EFILive's proprietary software ... this is protected by copyright, and hacking this would likely result in a law suit.
    Oct 2005
    Actually editing is actually supported by efilive when using third party tools.
    Its stated on the main site for use when only read and write of tune files is supported.
    Question is how to convert file formats!?
    http://www.efilive.com/flash-only-supported-vehicles
    2014 VF SV LS3 Maloo.
    Jan 2014
    Hello Ringram
    Thank you, yes you are correct,
    Im talking about the flash only supported cars, and how to use a third party sw to modify the files.
    The modifying is no problem at all,
    But the question is how to convert the file, from an autocal file, to a bin file, so we can import it into a thirdparty mapping software.?
    Well the short answer is you can't really use the reads as is. The idea behind offering any form of support for those type of ECM's in the first place was really for flashing. People use some third party software to edit a tune, import it into EFILive for flashing via passthrough or remote flashing via Autocal's. On ECM's like those Bosch ones we can convert the .ctz file in to a raw bin, but, there is specific rules to this. If it is an ECM EFILive supports actual tuning for then forget it, we also do this as a free service for customers so sending in 50Mb of reads isn't going to win you any friends either. If you have a few of these E55 tunes you need converted so you can use some 3rd party editing software then send support@efillive.com an Email with the details.
  1. Bad Flash (possible bricked ecu)
    By FreshDA9 in forum General
    Last Post: August 23rd, 2013, 07:46 AM
  2. E55 Saab Please!
    By ls1mike in forum Do you want to be a Beta Tester?
    Last Post: June 12th, 2013, 09:05 AM
  3. Cant Read ECU after EFI Live Flash
    By akcooper9 in forum Gen III V8 Specific
    Last Post: December 13th, 2012, 05:06 AM
  4. Scanning non supported ecu's
    By Tre-Cool in forum General (Petrol, Gas, Ethanol)
    Last Post: May 23rd, 2011, 10:13 AM
  5. is this ecu supported?
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 10th, 2010, 12:56 PM
