Results 1 to 4 of 4
Thread: Safe first flash on a P12 I6 2006 Envoy
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Default Safe first flash on a P12 I6 2006 Envoy
    I just want to make sure I dont mess anything up. I see where some other people have had issues here on the site when flashing these PCM's
    Im probably going to have the Dealer update the PCM with the Latest firmware to fix the idles issues this car is having (As they have rectified the aging Cam modulator with PCM updates) then do a read and make some further modifications to the computer.
    Any suggestions to being successful?
    -other than updating EFI live to the latest version before starting.
    Mar 2011
    I should be able to just pull down the calibration and modify it then upload it again correct?
    Mar 2011
    Pulled the stock tune down and the tables are totally different than the LS1 computer setups.
    Mar 2011
    Looks like those posts from a failed flash were back in 2010 so Im guessing its all rectified now?
  1. P12 Colorado Flash Fail
    By Duramax 6.6L in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 9th, 2016, 12:18 PM
  2. 06 gmc envoy p12 pcm issue
    By cyclerage in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 3rd, 2015, 07:57 AM
  3. OEM GM Stage 2 Flash for a 2006 Saturn Ion Reline 2.0
    By DaveGuy in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 11th, 2013, 07:40 AM
  4. Problem with 09 Envoy
    By Sparky8370 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: September 14th, 2008, 01:46 PM
  5. Could not edit my 03 Envoy I6 with the new release
    By LSRacing in forum General (Petrol, Gas, Ethanol)
    Last Post: April 24th, 2006, 11:46 AM
