I tuned a customers car using a license from my Flashscan- now I received an Autocal for his car-when I connect it will the license be used up that is on the Autocal or will it already recognize that this ecu is already licensed?
You'll need to use a new vin licence in the Autocal in order to flash it with the Auotcal.
Licencing of controllers is independent between Autocals and the parent V2.
Licensing schemes are device dependent - licenses are not transferable. If you want to tune a vehicle on a different device, it will need to be licensed to that device.
Licenses cannot be moved between devices.
Each AutoCal ships with 1 license to allow you to tune 1 supported vehicle. If you are tuning the vehicle in house and intend to sell the customer an AutoCal device and wish to minimise your cost, you should flash the vehicle with the AutoCal.
Cheers
Cindy
