Results 1 to 10 of 10
Thread: Buying a used Copy of EFI Live
    Apr 2006
    Default Buying a used Copy of EFI Live
    I just bought a copy used from someone on LS1 Tech and was wondering how to transfer ownership? Any help woud be apreciated.
    Oct 2005
    You can advise sales@efilive.com of your serial number etc.
    But you can pretty much just start using it. You might need to buy a license if its full, or upgrade it if you need the commercial version. Once you install the software and connect to it you should be able to get the licensing details off it.
    I trust you actually bought the hardware cable with the LED's etc and not just the software?
    2014 VF SV LS3 Maloo.
    When you bought it, did he give you the license key that goes with the cable hardware...?
    If he used up all the PCM licences (these are in addition to the license key), you'll have to buy one or more of these also.
    The software is free and is not sellable.
    EFILive Distributor Trippin's Avatar
    May 2004
    Quote Originally Posted by Rod
    Congrats!
    Download and install the latest version of software from www.efilive.com
    Plug in the black box to your PC.
    Launch the Tuning tool and go to Help>Flaschscan licensing
    and see if you have any licenses available.
    If not then go to the EFILive online store and purchase a couple. ($99.00 ea) You will need a license file in order to flash your vehicle. You can however read out the code or data log as many vehicles as you wish without any available licenses.
    Have fun, and welcome to the club!
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    He'll still need a software license key that is unique to the cable's serial number.
    May 2004
    Why?
    Won't the box work in any computer you plug it in to? I've run my cable on many different computers without entering in the reg key.
    If you go to "Help>Flashscan licensing" with the box plugged in it will display the serial number and the level of the cable.
    The reg key is for running Flashscan without the box plugged in, to avoid the dreaded "Demo" mode.
    www.socaldiesel.com
    Oct 2004
    Quote Originally Posted by Trippin
    Why?
    Interesting. I would have said the exact same thing as 'joecar'.
    When you have the cable connected and it recognises that you have a certain level of cable does it actually update the 'My Documents\EFILive\V7\User Configuration\License.txt' file?
    Andrew
    EFILive Crew
    May 2004
    Quote Originally Posted by Tordne
    To test it just rename that file and plug your box in and see if it works.
    www.socaldiesel.com
    Oct 2004
    DOH! That requires effort on my part . I will try thought, that is just the type of useless information I just have to know
    Andrew
    EFILive Crew
    Apr 2006
    Thanks for all the help!!
  1. buying a V1
    By barney28 in forum General (Diesel)
    Last Post: May 9th, 2010, 04:55 PM
  2. Im intrested in buying EFI...
    By cowboy2844 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2008, 05:22 PM
  3. 2000 truck with locked PCM, buying new PCM
    By SimpleManLance in forum General (Petrol, Gas, Ethanol)
    Last Post: January 10th, 2008, 05:06 PM
  4. buying another Vette PCM Serv. number differant?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: October 28th, 2007, 06:41 AM
  5. I am buying Flashscan, I run 20 psi...... What map sensor???
    Last Post: June 3rd, 2005, 10:17 PM
