Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: grid heater light/no code set?
  1. #11
    hey Les, thanks for jumping in, so I'm assuming you mean injector bodies?? It only happens under that condition, but I am having another issue that might be a cause. I have a wiring issue with the rear plug on my injector harness on the last 2 or 3 wires, if I wiggle them is cuts out the injector (and that sets a code, and a hell of a vibration I might add). I'm in search of a new harness and haven't been able to find one on line that's just the part I need. Can't afford to do the whole under hood harness. Could a slightly bad connection be causing the return issue?
    To Live, To Serve...
  2. #12
    Nov 2010
    The fact that your light/dings are under a substantial load, is indicative of the design of the software. Yes your injector bodies are tired and you need to look for new ones.
    The iffy wiring is more coincidence then anything.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  3. #13
    found set of injectors I can afford...anyone have a twin piping kit they'd like to sell?
  4. #14
    when you say software I'm assuming you mean whats left of the os from dodge right Les?
  1. Replies: 1
    Last Post: February 2nd, 2012, 10:58 AM
  2. Grid heater trigger-temperature
    By MQ105 in forum Cummins 5.9L
    Last Post: June 12th, 2011, 04:21 PM
  3. Check engine light/No code?
    By Brad-06-Dmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 14th, 2010, 05:25 AM
  4. Code U1000 Security Light on No start. HELP!!!
    By ls698ta in forum Gen III V8 Specific
    Last Post: February 14th, 2009, 10:28 AM
