Results 1 to 10 of 12
Thread: T43 TCM code $06FF: checksum failure
    May 2012
    Default T43 TCM code $06FF: checksum failure
    working on a XJ cherokee with a 08 5.3L 6L80E, dont know what year is the trans, i tried to load the stock tune and it say that it had a invalid calibration, i still read it, but didnt have VIN number and it looks like the tune was broken or something, so i took the OS (24239353) searched for a T43 stock tune on tunefiledepot and tried to do a FULLFLASH with the new base stock tune and when finish it says: code $06FF: checksum failure
    Any help? i dont want to swap the TCm,trans already has OIL
    What V7/V8 software builf version do you have installed...?
    Post the read TCM file here.
    May 2012
    I Have the latest updates on both software.. ill atach the tune i read from the TCM
    Operating System 24239353 $5D3F6A7D Checksum invalid.
    Transmission Operation 24244575 $09993A2D
    Transmission Diagnostics 24245507 $0AB96316
    System 24239147 $EDFBB7ED Checksum invalid.
    Your files are no good, as you can see the software is telling you the checksums are bad, the flash will not be allowed to complete if you try to put that tune in.
    That tune BTW is from around 2007/2008 so you are on the right track with finding the correct tune file to use.
    May 2012
    thanks for the help, that tune i atached is the one i read from the T43 TCM, it was like that when i started to work on this truck,, i used the OS and searched for tunes with the same OS and when tried to do a fullflash using V8 when finish flashing it it says about the checksum failure, im afraid that someone tried to do a flash with TIS and flashed and older calibration and thats why its like that, what i should do?
    Quote Originally Posted by 400ss View Post
    That is the case, your TCM is supposed to be running an OS from 2010 or later, the 24239353 is from 2007. You will need to find a suitable file (or VIN for TIS) to put the correct year OS in.
    May 2012
    thank you alot, that really helped, ill do that today and will se the results, thank you
    Jul 2011
    Default Same Problem
    GXP_T43.ctzI am having the same problem. I recently purchased a G8 GXP OS 24249179 and wanted to return to stock since I was unsure of the modifications done to the tune. So, I read the file, saved it, then changed some settings to match a stock Camaro since I could not find a stock GXP T43 tune and saved it with a different name. Upon flashing I got the $06FF error and was only able to have 3rd gear. I tried flashing the original file back with no avail. Tune is attached:
    That is not a stock tune, it has been altered by another tuning program (I suspect LS2 Edit) and they've messed with the checksums to disguise the tune. But I don't have an exact match tune for you to try sorry.
    Jul 2011
    Ok, I will try to get my buddy to see if he can flash with HPT. I really hate to take it to the dealership, but with this it is in limp mode so I am dead in the water.
  1. T43 checksum error
    By jims68 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 21st, 2014, 03:27 PM
  2. Replies: 2
    Last Post: July 17th, 2012, 04:27 PM
  3. Checksum code
    By mstordahl in forum Cummins 5.9L
    Last Post: March 2nd, 2012, 04:43 PM
  4. Holden / Pontiac TCM Checksum errors
    By bK in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 21st, 2008, 04:02 PM
