Results 1 to 5 of 5
Thread: 4l60e tranny shifting problems
    Apr 2006
    Default 4l60e tranny shifting problems
    Hi, to all on the forum. I'm the freshest newbie.. I have just started working with efi in the last few days. I'm trying to program a 01 ws6 with a build tranny. It has a stall and beefy internals, and it just will not shift worth a crap. I have been in the computer briefly and worked with a few different setting but nothing seems to be fixing the problem. I talked to another guy today that said the factory computer may be to blame. That everything works off voltages and the computer may not be making the changes..Any suggestions would be greatly appreciated..
    Oct 2005
    More details please.
    What exactly are you trying to achieve and what exactly is happening if anything.
    Also what are you changing to try to get it to work.
    2014 VF SV LS3 Maloo.
    Jun 2005
    What have you changed? Did you disable/reduce torque management? Did you alter the base shift pressures? Did you change the desired shift times? These are all tables that affect the shifting characteristics of the trans. Personally, I don't suggest more than a 10% increase in base shift pressures, more than a 15% decrease in desired shift times, and more than a 50% decrease of torque management settings. Doing these three combined should get your trans shifting harder & faster. If you have a shift kit installed, I wouldn't suggest anything other than stock settings. The only other settings that you should adjust in the trans is when the shifts occur (mph/rpm) and when the tcc locks/unlocks. Just my $0.02.
    Quote Originally Posted by vettenv
    http://efiforum.iqd.co.nz/showthread...ptive+learning
    Read this thread.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Vette, pm sent.
  1. looking for 4wd tranny tune. 4L60E T42 OS:24235341
    By harascho in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 4th, 2009, 01:32 AM
  2. 4l60e problems
    By chevyman98 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 20th, 2008, 03:21 AM
  3. 4L60E Tranny Temp
    By Rico in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 27th, 2006, 03:46 AM
  4. 4L60E Tranny Temp
    By Rico in forum General (Petrol, Gas, Ethanol)
