Results 1 to 3 of 3
Thread: Manual / Forced Regen with EFILive
    Lifetime Member Whippled 496's Avatar
    Sep 2006
    Default Manual / Forced Regen with EFILive
    Is it possible to do a forced regen on an LML with EFILive? If so, can you explain the procedure?
    2014 GMC 2500HD RCLB SLE
    LML / Allison
    The DVT options for the LML are not in the scantool, however, you could select as an LMM and try it. There is a few regen options at the bottom of the DVT selections.
    I would suggest the engine needs to be warm (and running of course), in P/N, then if you click the regen option and something is not right the ECM reports back what it is not happy with and that error is shown in the scantool.
    Sep 2006
    Thank you sir.
    LML / Allison
  1. Manual upshift downshift 1,2,3,4 on 4L60e without manual valve body
    By Test101 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 7th, 2013, 08:30 PM
  2. Prevent forced 1-2 upshift when in manual 1 and TCC lockup in 3rd.
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 2nd, 2013, 08:38 AM
  3. how to tell if regen is on
    By ods dan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2008, 01:51 AM
  4. manual regen on LMM's
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2007, 05:01 AM
  5. efilive v4 Manual
    By onsta in forum EFILive V4
    Last Post: April 11th, 2006, 08:56 AM
