Results 1 to 1 of 1
Thread: Issue with minimum injector pulse
    Mar 2010
    Default Issue with minimum injector pulse
    I am in the process of tuning my VE tables in Open loop and am seeing a problem with injector pulses. I just put in the 160 #injectors and it appears at slight throttle at cruise (70mph ish) the car is going supper lean. I have attached a log that shows the fueling is fine and then all the sudden the injector pulse drops to 1.114 ms and leans out bad. Also the car remains at this low pulse width for some time.
    My transient pulse is set to .75ms and my default min pulse is at .75
    Can anyone explain why the pulses are dropping to this specific value?
  1. Replies: 19
    Last Post: March 19th, 2014, 02:16 PM
  2. No spark??? No injector pulse.
    Last Post: February 14th, 2009, 03:19 PM
  3. Small Pulse Adjust/Low Pulse Width Injector Offset
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2007, 09:05 AM
  4. Injector pulse width
    Last Post: October 7th, 2006, 01:49 PM
  5. Minimum Injector Pulse Width
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2006, 11:28 AM
