Results 1 to 6 of 6
Thread: Can´t get idle ls3/480
    Junior Member Bert-Ola's Avatar
    Jun 2011
    Default Can´t get idle ls3/480
    Hello,
    I can´t get this GMPP ls3/480 to idle.
    Installed in 1999 corvette using original MAF and MAP.
    Engine runs but as soon I let of the pedal, engine stalls.
    Any tips?
    Jun 2011
    My fault, I got it running with more desired airflow up to 12 Grams/sec.
    Runs a bit lumpy, but it stays around 1000 rpm.
    Now: set injector tables, correct VE and MAF tables, do RAFIG.
    Are you running the LS3 from a Gen3 PCM...? If so are you using the LPE 58x/4x -> 24x/1x converter...?
    Jun 2011
    We are running the original LS1B PCM on a GMPP ls3/480.
    LS2 throtlle body
    LS1 knock sensors
    LS1 MAP sensor
    LS1 MAF sensor
    24x/1x reluctor wheel on crank
    Oct 2011
    little heads up for idle help with bigger cams, less timing at idle and more air, they have less tendency to stall like this when getting load at idle from power steering, ac, etc...
  1. gmpp 376 480 ls3 tuning
    By zayne0 in forum Gen IV V8 Specific
    Last Post: July 24th, 2013, 03:41 PM
  2. E67 ls3 - 480 cal
    By SBELGIO in forum Gen IV V8 Specific
    Last Post: March 19th, 2013, 10:57 AM
  3. Need help setting idle on ls3
    By Kqrouth in forum Gen IV V8 Specific
    Last Post: February 4th, 2011, 01:22 PM
  4. e67 ls376/480
    By rapidgb in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 05:13 AM
