Results 21 to 30 of 45
Thread: Can't load PIDS for BB log
  1. #21
    Jul 2005
    More minor difficulties between last nites shakedown and todays BB log run. In log 0069 Absolute Throttle position stays at 0% and Ignition Timing for Cyl #1 stays at -64 deg but both report normally in log 0068. Not concerned with idle air flow, did not have proper pids selected.
ID:	16786Click image for larger version.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
  2. #22
    Your vehicle is 2000 Corvette...?
  3. #23
    Jul 2005
    Yes, with COS 2030003.
  4. #24
    Jul 2005
    Well this is getting frustrating. First of all ignore post 21, somehow the log reported properly. When I validate the FSP a 2kb file named 'external' is written. When I plug into PCM, automatic validation, a 5kb file is written named '1G1YY32G_Y5' is written. When i use the menu bar validate a 7kb file named '1G1YY32G_Y5_10' is written. You'd think they would all be the same size.
    Is scan looking for the proper protocol in SAE J1850 VPW? I end up with anywhere from 348 to 370 validated pids usable while plugged into PCM.
    There's a lot of talent on this forum, somebody has had to have destroyed their laptop and start all over.
  5. #25
    After you did that, does the V1 programming popup show non-zero pid channels...?
  6. #26
    Jul 2005
    Yes but only till FSP is disconnected once from scan, like saving a Pid selection or just disconnecting. When FSP is reconnected only Pids with 0 channels are valid and these approx 70 Pids are unload-able to FSP.
  7. #27
    Jul 2005
    Misunderstood, once Pids are loaded in FSP they remain and are usable. I was mistakingly referring to scan validation.
  8. #28
    Jul 2005
    Well I believe it's a licensing issue. After validating Pids help/about still reports generic vin, PCM as N/A and PCM OS as N/A. Still no pids with a channel association selectable unless connected to PCM. The only difference I see is my upgrade is dated 15 Feb 2006 and my flashscan reports 18 Jan 2005. Anyone?
  9. #29
    I can confirm that there is a bug in the V7.5 software that will not load the validated PID list from a *.vpl file unless a vehicle is connected.
    It will be fixed in the next update.
    Meanwhile, you can fool the software into loading your validated PIDs by deleting the external.vpl file and renaming your vehicle's actual *.vpl file to "external.vpl". That will force the software to load your vehicle's validated PIDs when no vehicle connection exists. That is because when no connection exists it is only loading the external.vpl file (which usually contains the valid external PIDs, i.e. the analog voltage PIDs for FlashScan).
  10. #30
    Paul, thanks, that is an interesting workaround
  1. PIDs to log?
    By Mikz86ta in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2013, 02:50 PM
  2. What pids do I need to log?
    By Cool28 in forum Gen III V8 Specific
    Last Post: November 22nd, 2011, 02:27 PM
  3. Replies: 2
    Last Post: September 8th, 2011, 11:07 PM
  4. Can't log some airflow PIDs
    By O1Z06 in forum Petrol / Gas
    Last Post: February 21st, 2011, 05:03 AM
  5. How do i setup my PIDs to log?
    By RyanU in forum External A/D inputs
    Last Post: September 5th, 2008, 10:17 AM
