Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Can't load PIDS for BB log
    Jul 2005
    Default Can't load PIDS for BB log
    Launched old laptop from roof of car. Downloaded V7.5.7 Build 245 on different XP laptop using FSP 1.2 . Overcame the licensing but am unable to load PIDS for BB logging. Help would be much appreciated.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Feb 2012
    USe the v8 program to set up a v2 for BBL.
    Jul 2005
    I use a V1 for BB and ver 7.5 is the latest upgrade. I actually loaded PIDs to black box while connected to PCM. Forgot to mention I use COS 200303. Logs correctly straight to computer but BB logging the same PIDs 60% are showing N/A. Am suspecting a failed cable
    Feb 2012
    Missed that bit, sorry. I didn't realise a v1.2 could do BBL.
    Problem sounds a bit like in this thread: https://forum.efilive.com/showthread...into-flashscan
    Jul 2005
    Wish it where that simple.
    Your PIDs tab shows 19 selected pid and 0 selected channels...?
    Try this:
    on the FlashScan Control Panel (for V1) do this:
    - select Fast (10 f/s),
    - set Max Frames Per Log to zero (i.e. unlimited),
    - click Validate;
    - follow the instructions it tells you (it will tell you to connect V1 to vehicle and let it validate, and then to bring it back to PC).
    Jul 2005
    Followed our instructions up to validate, was warned all log files would be erased, clicked yes to continue and was told Flashcan is now ready for validating pids.No further instructions.
    I thought all colored pids where selected. How do you select channels?
    Jul 2005
    It's been four years since I tuned my ride. Fell into a brand new hole here. Flashscan control panel reports 1 total log file plus time/log @ 01:13:38 and total time @ 01:13:38. Looks like its gorged.
    Ok... (it's been a long time since I did V1 BBL)... I sent Paul an email for further guidance
    ( the channel count should not be showing up as zero )
    Try this: click the Progam Pids button.
  1. PIDs to log?
    By Mikz86ta in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2013, 02:50 PM
  2. What pids do I need to log?
    By Cool28 in forum Gen III V8 Specific
    Last Post: November 22nd, 2011, 02:27 PM
  3. Replies: 2
    Last Post: September 8th, 2011, 11:07 PM
  4. Can't log some airflow PIDs
    By O1Z06 in forum Petrol / Gas
    Last Post: February 21st, 2011, 05:03 AM
  5. How do i setup my PIDs to log?
    By RyanU in forum External A/D inputs
    Last Post: September 5th, 2008, 10:17 AM
