Results 1 to 10 of 20
Thread: Added CPP to LS1b, what tables are affected?
    Nov 2013
    Default Added CPP to LS1b, what tables are affected?
    2005 LS1b, LQ9, 228R cam, headers. M6 trans.
    I started with a mail order tune which got me running(good not great). The tune was setup to run without a CPP. I want to make sure I update all the correct tables now to reap the benifits. If you guys know of anything else I should be concentrating on, I'm all ears(and eyes, well, mostly just eyes).
    I'm aware of TC and TF in Gear and P/N.
    Rolling Idle is currently zero'd out...will this ask for "zero" rpm if I depress clutch and TC is active? Maybe just enter 800rpm across the board?
    Base Spark in Gear{B5932}
    Base Spark P/N{B5933} these are the same...should I change them?
    Lastly, and keep in mind I'm new, after I complete RAFPN, do I need to redo now for RAFIG?
    Thanks for any responses guys.
    Jul 2005
    CPP?
    peace
    Hog
    Nov 2013
    Sorry, What I mean to say is that I added the Clutch Pedal Position sensor to the ECM(Blue connector, pin 35), hoping to get some better drivability by letting the ecm know that I've clutched in/out.
    Nov 2013
    any other experiences or advice from those who have added a CPP signal to an LS1b..or any ecm?
    New Member Gama6970's Avatar
    Feb 2011
    hello Jetmech442, im debating on doing the same thing to mine. did it help? what issues did you have to work out?
    Nov 2013
    Made a world of difference. For my setup, LQ9, 228R cam, Lt headers, LS6 intake, T56 trans....I changed the following table:
    B4310-Throttle Cracker P/N: added .50 lbs/min for 2-6 mph.
    Wiring in the switch and changing the table eliminated the erratic behavior when I would try to roll to a stop with clutch depressed.
    Theres a pic of the wiring in my build thread over on LS1tech...
    http://ls1tech.com/forums/conversion...version-3.html
    Feb 2011
    thank you so much. that explains what I'm getting.
    Jan 2014
    thread hijack- maybe I need a CPP?
    I don't have surging- but at the beginning of some of the drives my truck will die when I push the clutch in and throw it in neutral while getting on the brakes(power) all at one time. Seems like this 'shocks' the system and it'll die. I do not have a CPP- I do have the brake system hooked up so my cruise works.
    I'm basically wondering, is my problem no CPP, TC or TF?
    I have rolling idle set to hang up over 1k. and basically as soon as I drop below my specified mph and the rolling idle decays the truck dies- like it literally has no airflow. MAP slowly and steady rises to ambient. Sometimes if I'm just moving the truck around back and forth it will die when I clutch in and brake at the same time. I'm nearly at a loss. Anyone have ideas?
    Jan 2013
    When I first started tuning my converted car I was using the common 12212156 OS from a US based vehicle. My wiring loom was from a Monaro and didn't have a CPP provision. When I logged the TF/TC PIDs I quickly realised they weren't doing anything and I had some surge/stumbling issues after fitting a cam.
    Rather than wire in a CPP I switched back to an Aus based OS 12225074 which cured my issues and the TC/TF tables started to work.
    So I'd advise logging your TF/TC tables to if the values are actually working. If the values don't change then you may have to either wire in a CPP or try the 12225074 OS. If the values are changing then they probably just need some tuning to help.
    Jan 2014
    Interesting.
    I need to understand more about TF/TC. When each should do what, and when.
    When I log them, they are certainly working( I think). Maybe just set incorrectly? But they also seem to be working erroneously.
    When pushing in the clutch, shifting to neutral, and getting on the brakes- which (TF or TC) should function and how? It seems when this problem occurs from my logs, at soon as the clutch is pushed and the truck taken out of gear the MAP starts to rise like the engine is basically dead. By increasing rolling airflow it has helped a bunch- but the truck will learn down to what it actually needs and the problem comes right back.
    So I assume I don't have enough TF or TC, or the decays are wrong. I'm looking for a good log file to post- I know I have one but I'm trying to sift through them all. I did attached a picture of a log when the truck dies. You can see TP drop, MAP initially drops(more vacuum) until clutch is pushed, then MAP rises to ambient as engine dies- truck rolling the entire time.
    Since this log I have activated rolling hanging idle- but it is merely a band aide. If I deactive it I can't drive the truck as it constantly wants to die. RAFIG has been done and is correct. I believe my issue to be TF/TC/ or CPP problem- and I'm pretty certain it's one of the 3.
  1. Throttle Cracker - No CPP due to being a Holden PCM
    By bimbleuk in forum Gen III V8 Specific
    Last Post: September 9th, 2014, 12:40 AM
  2. Remote start affected?
    Last Post: February 13th, 2011, 03:38 AM
  3. Replies: 6
    Last Post: October 24th, 2007, 06:16 PM
  4. Added a New Gauge!
    By mistermike in forum Lounge
    Last Post: January 17th, 2006, 04:23 AM
Tags for this Thread
