hello Jetmech442, im debating on doing the same thing to mine. did it help? what issues did you have to work out?
Made a world of difference. For my setup, LQ9, 228R cam, Lt headers, LS6 intake, T56 trans....I changed the following table:
B4310-Throttle Cracker P/N: added .50 lbs/min for 2-6 mph.
Wiring in the switch and changing the table eliminated the erratic behavior when I would try to roll to a stop with clutch depressed.
Theres a pic of the wiring in my build thread over on LS1tech...
http://ls1tech.com/forums/conversion...version-3.html
