Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: Help with csp5 2800rpm fuel issue?
  1. #31
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    Can you post your log file
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
  2. #32
    Senior Member tylerltr450's Avatar
    Aug 2014
ID:	19450Click image for larger version.
    You adjusted all of this?
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
  3. #33
    Nov 2015
    Quote Originally Posted by garrettg.bpd View Post
    Here are my last three
    CMB_0025.efi
    CMB_0026.efi
    CMB_0027.efi
    Quote Originally Posted by tylerltr450 View Post
    Yes I do have all those tables adjusted.
  4. #34
    Jun 2013
    It appears that your hitting a rpm limiter. I would say log with all the EDA pids. Post your new logs with all the pids and raise the rpm limiters to what you feel is safe for your engine.
    EFILive Beta Tester
  5. #35
    Oct 2014
    You need to adjust this table. Read each one carefully and adjust as you see fit. This is my current table. I shift at 3900 rpm and have no de-fueling issues. With some adjustments I've run my truck up over 5,000rpm and most of the adjustments need to be to this table. As long as you have all of the other limiters taken care of this should help you.
  6. #36
    Nov 2015
    I will add all EDA and log again.
    Quote Originally Posted by Dom_c13b View Post
    Ok, well I thought I had those tables taken care of but maybe not. I'm just going to copy yours there and see what it does on next log.
    Thanks for help guys. I will post back with results.
  7. #37
    Oct 2014
    Yea let us know the out come. It took me a long time to finally figure out full fueling above 2800rpm, I feel like I searched and read every thread about it but never found much conclusive. A lot of people like to hold on to those secrets it seems.
  8. #38
    Nov 2015
    Ok so i logged with all EDA parameters and changed my limiters to match the ones posted. It's definitely better but still not quite 100% there. I didn't get a chance to do a real good WOT pull either on this run but you can still see it taper off. I am getting over 2000us easily now especially in the lower gears. Here is a snap shot of log; my log file is slightly too big to attach. I also attached my tune.
    Also, off-topic side note here, I adjust my main timing table up a bit and wow made a big difference in pep and power and much less smoke. I think I can even go a little more on my timing.
Name:	better fueling.PNG
    CSP5 tune hi_idle 06_07_0007.ctz
  9. #39
    Oct 2014
    I can't open your tune file for some reason. Do you have a real old version of efilive? I'd like to check it out. I'm sure we can get it to fuel harder
  10. #40
    Member arinkuddy's Avatar
    May 2014
    You need to adjust this limiter
    you might try setting this to minimum as well
  1. Issue with upgrading to CSP5 operating system...
    By LPDTuning in forum Cummins 5.9L
    Last Post: December 3rd, 2013, 04:09 PM
  2. Issue with CSP5 switching
    By saintb6969 in forum Cummins 5.9L
    Last Post: November 20th, 2013, 02:54 AM
  3. Strange fuel issue
    By Forcefedperformance in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 24th, 2009, 07:13 PM
  4. Fuel injection issue
    By odd boy in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2008, 02:50 AM
  5. Fuel Issue
    By Beer99C5 in forum Gen III V8 Specific
    Last Post: May 19th, 2007, 11:08 AM
