I keep getting $0205 error, while trying to update ECM with tunes, in fact none of them work!
Its driving me crazy, I think my AC is up to date, unless i missed something. Working with window 7 and a E67 ECM. Any suggestion?
Has the device been setup for E67?
Is the AutoCal running the same software and firmware version as the FlashScan used to create the tunes? Both devices should be running our Nov 5 public release software, or our Nov 21st Pre-release software versions. Downloads can be found here http://www.efilive.com/latest/cat/download-efilive
With AutoCal connected to your PC, start the V8 Scan and Tune (S&T) software, click BBx, click Tune, select your ECM/TCM from the list, delete all others that do not pertain to you, click Save, click the down arrow next to Program, click Program All.
Cindy
Thanks!! ill be rechecking all the data to make sure! !
