Results 1 to 3 of 3
Thread: Torque Signal Pressure
    Feb 2013
    Default Torque Signal Pressure
    I'm trying to dial in my 4L80E shifts focusing on the 1-2 shifts at the moment. When cold it shifts nicely, but when warm it shifts much firmer and is very annoying. Desired shift times are all set to zero because it has a shift kit. Shift base pressures are stock.
    I've been tinkering with D0704 "1->2 Temperature Pressure Adjust". The units are PSI per second with limits of -96.0 to 96.0. Should I reduce these values to soften shifts or increase them? I've moved them from 0.0 to -4.0 when warm and it didn't seem to make a difference.
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Try -15 psi/s.
    This table adds to the corresponding shift pressure table, so -15 psi/s will subtract from shift pressure table.
    Or, try some different values (-15 psi/s) and see how it behaves.
    Feb 2013
    Thanks Joe. I tried -15psi/s and it helped slighly. The shift is overly firm at low throttle (<10% TP) but decent otherwise. I should probably adjust the base pressure first.
  1. Barometric Pressure Torque Limit B1128?
    By Mad Maxx in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 13th, 2010, 04:38 PM
  2. Speedometer signal
    By Hocky in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 10:14 AM
  3. MAF Signal
    By Spindoctor in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:23 PM
  4. torque`signal
    By 69camaro5speed in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 6th, 2006, 03:26 PM
  5. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 05:16 AM
