Results 1 to 6 of 6
Thread: Dashboard help
    Apr 2014
    Default Dashboard help
    I can not figure out how to build usable gauges. I am trying to datalog data on an A40 Allison 6spd. Does anyone have a dashboard with the following gauges from the TCM:
    TPS%
    Gear
    VSS
    TCC Lockup
    TFT
    I don't care what they look like as long as I can data log the info to help fine tune my shift points.
    Thx
    On the Dash A tab, do rightclick and choose a theme and choose a gauge...
    then on the gauge do rightclick and choose a pid...
    then on the gauge do richtclick->Properties and edit the high/low marks and the various properties to taste, click save, end exit.
    Apr 2014
    i will give that a try tonight. will it be that easy to build a gauge to tell me what gear the trans is actually in as it shifts?
    Apr 2014
    got everything to work except a tps signal from the tcm. do you know what pid to add for this signal in an A40 tcm?
    thx
    The only pid that comes close to being TCM throttle position is "Throttle Angle at Shift" GM.TPSSHFT, and I don't know if it is supported by A40.
    Apr 2014
    ok, ill check to see if that is the one that i used or not.
    thx
  1. How do I setup a dashboard
    By TJWells in forum E37, E38 & E67 PFI ECM's
    Last Post: February 17th, 2013, 06:17 AM
  2. dashboard
    By fotograf2 in forum General
    Last Post: August 11th, 2010, 07:58 AM
  3. Having problem with dashboard.
    By Brian1 in forum General
    Last Post: December 30th, 2008, 10:44 AM
  4. Trying To Decide On New Dashboard
    By Dennis93TA in forum General
    Last Post: September 10th, 2007, 02:19 PM
  5. Custom dashboard
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2006, 05:32 PM
