Results 1 to 9 of 9
Thread: GENIII LS1B Blue connector pin 33 funtion
    Jul 2012
    Default GENIII LS1B Blue connector pin 33 funtion
    I'm trying to get a straight answer as to what the blue connector pin 33 is responsible for on an LS1B computer. Both the F body and trucks have it and I am aware that it is used for TCC unlocking on an automatic trans vehicle. My question is does a manual trans use this pin for anything? Does the computer want to know when the brake is on for any sort of deceleration function (both in an auto and manual)? Is it purely for TCC unlock on an auto and nothing else??? I've asked this question to a few different people and have gotten a few different answers.
    Feb 2008
    Should just be for the TCC solenoid control only.
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
    Jul 2012
    That's what I thought until I pulled apart a factory 2000 Silverado harness from a 6.0/nv4500 and it had the purple wire coming from a body connector and going into b33. Its not like chevy to run a wire without a purpose like that. Surely the ecm is reading that pin for some reason, but what???
    Jul 2012
    Here's the circuit in question...
    Possibly the PCM might be able to do brake torque management on a manual trans... but IDK for sure.
    Aug 2011
    I dont know if its in the bcm or ecu, but doesnt the ecu read the brake wire durring CASE Relearn's to ensure you foot is on the brake? I know its not something that is important for daily function buti believe it is needed for that.
    Jul 2012
    Good point cyipher!
    May 2012
    ECO on what cyipher says
    Jul 2012
    I'm bringing this back up, I agree it should be there for the CASE relearn but has anyone learned anything if it has other functions in the tune? I hate not knowing. I convert a lot of harnesses for stand alone and it bothers me to not have a 100% grasp of what all the wires do.
  1. ALDL (GM OBD1) cable with 16 pin connector ,USB
    By wahenn2002 in forum EFILive V4
    Last Post: January 22nd, 2012, 06:10 PM
  2. 2002 PCM Red connector pin#51 Transmission Temp Signal 4L80E????'s
    By GAMEOVER in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 5th, 2011, 05:18 AM
  3. WtB junk pcm & red & blue connector to buld a 97/98 to 99/04 harnes
    By Treurentner in forum Gen III V8 Specific
    Last Post: July 19th, 2007, 03:58 AM
  4. shift patterns with pin 71 and pin 31 questions
    By Jdperk-86elco in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 23rd, 2006, 03:20 PM
