Results 1 to 10 of 13
Thread: Stock Tune for 09 CTS-V Manual
    May 2014
    Default Stock Tune for 09 CTS-V Manual
    Helping a friend out with some tune issues, he bought the car with mods done, returned it all to stock, and flashed his "stock" tune back with SCT. I was able to read it with EFI. The car runs horrible and the LTFTs go to 25-30% Engine load is 15-20% also. Smoked the intake system and didn't find any vac leaks. Compared his tune to an 09 LSA Automatic and there are quite a few differences. Anyone have a stock manual tune I could use to compare and possibly flash?
    Apr 2007
    Here is list of stock tunes you can download. Make sure to match the operating systems.
    http://www.tunefiledepot.com/index.p...Type=P&Stock=Y
    May 2014
    I took a look on there. The only tunes I can find are for automatics. Nothing with a manual trans. I'm not sure what the actual differences are. If someone wouldn't mind taking a look at this tune I would really appreciate it. This is supposed to be a stock tune. However it runs with the LTFTs maxed out.
    Apr 2007
    That is NOT a stock tune you posted. No wonder it drives so bad. It has a lot of parameters changed and DTC's disabled. It must have been a radical set up based on the tune. Anyway, I did find what I believe is a stock tune. I tuned my friends 09 M6 V and found this file. Do you know how to use the compare feature?
    Apr 2007
    They disabled LTFT's because they're set to enable/disable at 283 F. Who did that tune?
    May 2014
    Did it open for you? Im getting an integer overflow error when I try to open it. Might be something with my computer.
    Thank you VERY much for that tune. I really appreciate your help.
    May 2014
    I'm not sure who did the tune. He bought the car with a pulley, injectors and some other mods. He returned it to stock mechanically. The previous owner gave him an SCT programmer with a modded tune, and what was supposed to be the stock calibration. The car wouldn't run at all with the custom tune, and it runs, but terribly on the supposed stock tune.
    I noticed that about the LTFTs. They stay at 0 unless I force LTFT learning with DVT.
    Apr 2007
    You may have an older version of EFILive. The calibration you posted is in the older "tun" format. I file I posted is "ctz" format. Try a 'save as" to see if it lets you save it as a ctz file.
    Apr 2007
    Try this one. I changed all of the parameters saved it in the tun format.
    May 2014
    Yup its saved as a ctz file. I tried opening it in both V7.5 tune tool, and v8 scan and tune. Both are the most current software. Hmm. Maybe i'll try reinstalling.
  1. Need a stock tune for 06 manual trans
    By protraxrptr17 in forum Cummins 5.9L
    Last Post: February 15th, 2013, 01:30 PM
  2. Looking for a stock vin tune for a 05 CTS-v
    By LantzCTSV in forum Gen III V8 Specific
    Last Post: November 16th, 2012, 08:13 AM
  3. Long shot - anyone have a stock maggie tune for the LS2 CTS-V
    By ichpen in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 17th, 2009, 03:00 AM
  4. Need stock SS Camaro tune (manual)
    By Boost in forum Gen III V8 Specific
    Last Post: October 17th, 2007, 05:33 AM
  5. HSV Clubsport/R8 Manual Tune (Stock)
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: December 13th, 2005, 09:50 AM
