Results 1 to 8 of 8
Thread: MAP vs BARO at WOT
    Lifetime Member samh_08's Avatar
    Oct 2008
    Default MAP vs BARO at WOT
    Today I was messing around with the car again and am getting about 93.5kPa average manifold pressure @ WOT. MAP read 97kPa before start up, so Im assuming thats BARO.
    Before I start tearing stuff apart looking for a restriction, I'd like to know what others experiences have been. Care to share?
    Yes, that's BARO (MAP before starting engine).
    It's usual to see about 2 kPa drop depending on vehicle... some vehicles you see less drop.
    Post a pic of your intake/MAF plumbing...
    What MAF do you have...? It most likely is not the MAF. It most likely is the plumbing and/or air filter.
    Remove the air filter (if you dare) and do your measurement again.
    Edit: correction.
    Oct 2008
    2 psi or 2 kPa drop? I will post a pic of my intake later today but its all 4" to a 4" filter with no MAF.
    2 kPa
    Thanks ( sorry, I was typing ahead of myself )
    I always deal with MAP, MAF, IFR in Metric;
    the only objects I use Imperial for are: temperature, speed, torque, oil/ATF/AC pressure... almost everything else is Metric )
    Aug 2013
    I've got a stock LS1 intake with MAF. I'm at sea level, 101kPa baro. At WOT I'm seeing 97kPa @ 5800RPM with IAT @ 26C.
    Oct 2008
    Im dropping the about the same kPa as a stock intake makes we think its my throttle body/intake opening.
    Heres some pics:
ID:	16891   Click image for larger version.
    What is the diameter of the long pipe...?
    Experiment: remove the pipe from the two elbows at the TB (leaving one or two elbows), try this and see what MAP is; the length of the plumbing can influence the drop, either by restriction or by resonance.
    Oct 2008
    Everything is 4" smooth pipe. Will try removing some parts this aft depending on weather.
  1. Please confirm the Redline Ion MAP/BARO values....
    By Redline Motorsports in forum Gen III V8 Specific
    Last Post: September 2nd, 2011, 12:50 PM
  2. Baro PID
    Last Post: April 28th, 2009, 02:32 AM
  3. Baro sensor
    By billiardcue in forum General
    Last Post: May 15th, 2006, 01:00 AM
  4. WOT MAP Values(kPa)
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 16th, 2005, 02:34 PM
  5. baro and 2bar setup
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: July 4th, 2005, 03:34 PM
