Results 1 to 9 of 9
Thread: TPS won't reset to 0%
    Aug 2005
    Default TPS won't reset to 0%
    My TPS will not ready 0% once the engine is running. With key on and the engine not running it will read 0 but once I start the engine it reads around 2-4%. Sometimes it will read around zero and the car idles good then but when it is around 2-4% the idle surges a lot. It kinda seems like possibly a ground issue but I'm not sure. This is on a 2000 Camaro.
    John
    2000 SS Camaro
    LSX 427 with GT55-94mm
    9.77 @ 157 4030 lbs race weight
    May 2012
    If you think its a wiring problem, try checking the continuity of the wires, on LSB1 PCM the 3 wires from the TPS goes to the PCM.. if everything its ok try adjusting the TPS phsically
    Aug 2005
    Yeah I'm going to check the continuity from the tps connector to the pcm. I've adjusted the TPS physically and reset the TPS but still acts the same. Researching on LS1tech someone says maybe the pcm but I'm going to check the wiring first.
    John
    2000 SS Camaro
    May 2012
    check it out and update the results, im sure people will help
    Remove the connector, short the signal to ground, see what scantool shows.
    Aug 2005
    I figured out by checking the resistance between the connector and the pcm pin that the signal wire was bad. After running a new wire the TPS reads zero with the engine running.
    John
    2000 SS Camaro
    Cool
    Where did the wire break (how far back form the sensor connector...?)(this is on a 4th gen F-car...?)...?
    Aug 2005
    I don't know. I didn't undo all the wire loom, I just ran a new wire since I didn't have time to really look into it.
    John
    2000 SS Camaro
    If it's a 4th gen F-car it probably broke close to the lid.
  1. tps won't read 0%
    By steve40 in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 12:56 PM
  2. Alpha N (TPS Load) help... noisy TPS signal?
    By Tomato in forum Gen III V8 Specific
    Last Post: July 4th, 2008, 10:22 PM
  3. TPS won't go below 14%, or above 88%
    By AustinL911A in forum Gen IV V8 Specific
    Last Post: January 7th, 2007, 05:07 PM
  4. TPS reset
    By Camaro SS in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2006, 02:59 PM
  5. VE Multiplier vs. TPS vs. RPM table, with non-linear TPS...
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 11:46 AM
