Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Enable Tap UP Tap Down in Engine SWAPs using corvette tcm tune and external switchs
  1. #11
    May 2012
    Exactly as de corvette a6 diagram using the corvette tune
  2. #12
    Feb 2015
    Thanks. Trying to figure my system out. I have a converted harness from a 2012 Caprice and there is only one wire going to the transmission for the TU/TD.
  3. #13
    May 2012
    Yes.that wire comes fromthe tap up tap down circuit
  4. #14
    Feb 2015
    Does the switch you used have two or three leads on it? I'm using a Malibu shifter and if I remember correctly, it only has two leads on it.
  5. #15
    May 2012
    If the switch has 3 leads it can be used for up and down shift. If it has 2 . Itll be used for up or down
  6. #16
    Feb 2015
    Hi Guys,
    Overline Technology make a module that allows TUTD and also displays the correct gear on a display.
    I think you can use any TFT display you like also.
    https://www.facebook.com/video.php?v...933147&theater
    This is also done via CAN Bus.
    Cheers
  7. #17
    Jul 2015
    Default Hoping for pix of tutd toggle switch shifter for 6L80E
    Quote Originally Posted by 400ss View Post
    400ss, do you have pix of a shift circuit with the 8.25, 4.42 and 1.5 ohm resitors in it with a rocker spring loaded toggle switch? I appologize im not the best with reading wiring scematics but i can look a picture of an actual unit you have put together and i can build anything i can see a picture of. Is this possible? Thanks so much. reply to atlasman75@yahoo.com
  8. #18
    Lifetime Member blindawg's Avatar
    Sep 2010
    Can I change the ohms values the TCM needs to see? THAT would be super beneficial.
    The truck shifter sends out values of: 6.84, 3.97, and 1.87
    Verses the corvette's 8.25, 4.42, and 1.5. If you could make that an option it would help all the guys doing these swaps.
  9. #19
    May 2012
    to be honest i think it cant be done on the TCM,, but is fairly simple to do the circuit with the correct resistors,,
  10. #20
    Sep 2010
    I agree, except the truck shifter is set up different than the Vette shifter. I'll try to find a diagram.
    For and upshift command it goes through 1 resistor. For a downshift command it goes through 2 resistors, and for the steady state pull up value it goes through 3 resistors. All of which are inside of the shifter and I'm not so sure how easy it will be to get to it to modify it. My shifter should show up this weekend and I will try to take it apart to see if it can be done.
    I did find some info from GM that said the steady state should be between 8.11kohms and 8.39kohms. this means it should have the same value as the Vette does for the steady state. The numbers I posted in my first question was from a guy that measured it and posted onto a forum. I guess I should have waited until I got my shifter and tested myself. It may need no adjustment at all.
    Thanks for the help 400SS. You seem to always have the answer for the 6L80 questions I have!
    Branden
  1. 2012 Vette 6l80 tune in older trans for faster tap up tap down and rev matching
    By RD in SD in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 24th, 2015, 01:36 PM
  2. TAP Preset
    By L31Sleeper in forum Allison 5 & 6 Speed
    Last Post: April 19th, 2011, 04:14 PM
  3. Tap up/down TCC during shifts?
    By ssvolvo in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 16th, 2011, 11:29 PM
  4. Reset Tap Cells
    By jaydog in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 23rd, 2009, 08:05 PM
  5. Upgrade from auto tap to v2?
    By poolshark021 in forum Purchase and Shipping
    Last Post: May 2nd, 2006, 04:05 PM
