Results 1 to 5 of 5
Thread: External input
    Apr 2006
    Default External input
    Can someone tell me the sampling rate for the external ch?
    How fast can EFI track a changing voltage?
    Is there a configuration for a pulse counter?
    Thanks!
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Bump.
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Oct 2004
    Given that the quickest sample rate is 10 frames per second I wouldn't expect you to see any more than that in a log file. I think most WB02's sample at more than 10 fps but you don't get the extra resolution in the logs.
    Andrew
    EFILive Crew
    Sep 2003
    What I like to use the input for is supercharger rpm.
    May 2006
    You could always use a frequency to voltage converter like nationals LM2907
    and run it to your analog input.
    Link to LM2907 Data Sheet http://www.national.com/ds/LM/LM2907.pdf
  1. HELP! No external voltage!
    By gotabav in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2008, 10:52 PM
  2. Making an external MAP input device, need data!
    By Redline Motorsports in forum General
    Last Post: November 9th, 2007, 09:54 PM
  3. External Input Signal Noise?
    By dc_justin in forum FlashScan V2
    Last Post: January 19th, 2007, 07:38 PM
