Results 1 to 2 of 2
Thread: C1806 1807 and 1808 Gone with DSP2 or 5
    Feb 2013
    Default C1806 1807 and 1808 Gone with DSP2 or 5
    Hello,
    On my LBZ OS 12606128, I noticed that the Fuel Pressure error --> Rail Pressure Delta, Max and Min tables are gone after converting to a DSPx operating system. I was wondering if there was any intention on adding these back in?
    If I need to make changes, I have to do before the conversion, then copy all my other modified tables over.
    Thanks!
    EDIT: I think I put this in the wrong spot. ;-( Mods, can you move into : TuningDieselDuramax 06 LLY / 06+ LBZ & LMM?
    Nov 2005
    Quote Originally Posted by matchrocket View Post
    Hello,
    Thanks!
    DSP OS's contain a subset of tables from the main OS that can be modified. These are key tuning tables determined by the Beta Test team back in 2009 and are limited in number by available ECM space. There is no intention to modify or change any DSP parameter.
    You are correct, if you need to make changes to those tables, you will need to modify those before converting the file.
    Cheers
    Cindy
  1. DSP2/5 Question
    By JrTuner in forum Duramax LB7
    Last Post: September 9th, 2009, 04:28 PM
  2. DSP2 issues
    By rushingbc in forum General (Diesel)
    Last Post: January 28th, 2007, 01:01 PM
  3. DSP2 enable
    By Kennedy Diesel in forum Duramax LB7
    Last Post: July 2nd, 2006, 01:39 AM
  4. Dsp2
    By Drywall1 in forum General (Diesel)
    Last Post: March 3rd, 2006, 07:39 PM
