Results 1 to 8 of 8
Thread: E92 Driver Demand Vertical Axis Clarification
    Default E92 Driver Demand Vertical Axis Clarification
    The vertical axis in Drivers Demand table {B8802} it is noted as RPM or SPEED. Where is this coming from? If speed can we assume MPH?
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jul 2003
    Kph
    ALL GM's computers from 2005 or so are coded in metric, so always assume metric, the conversion to imperial is handled by EFILive. However, this is a special case because these numbers are not normal, they are floating point numbers which means what you see is what you get, there is no scaling to MPH, KMH, DegF, DegC etc, it is what it is. The numbers are defined in an axis and that is what EFILive is showing.
    Jul 2003
    That means we can change that axis? there is an n/v ratio set to 1 so doing that means kph... but one could back calculate rpm this way... newer ECUs use RPM as the axis from factory
    No, you can't change the function used, it is either RPM or KM/H.
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Is it safe to bump these tables by % ?
    Mar 2011
    The Answer is yes. It is Safe. Try to keep the 0 TPS like stock.
    Quote Originally Posted by HellKnightHicks View Post
    Thanks for sharing
  1. Displacement on Demand Lifters
    By NateD4 in forum Lounge
    Last Post: January 13th, 2012, 11:49 AM
  2. Displacement on Demand
    By Cougar281 in forum Gen IV V8 Specific
    Last Post: February 10th, 2008, 06:14 PM
  3. Need a Down Under Clarification
    By TAQuickness in forum Lounge
    Last Post: February 25th, 2006, 07:58 AM
  4. Demand of 7.0
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: November 22nd, 2004, 09:28 PM
