Results 1 to 8 of 8
Thread: log file names
    Aug 2011
    Default log file names
    Im logging an ls1b pcm and and right now the file gets named ls1b0001 and on up from there. Is there any way to log it with just a number such as 001 and up? No ls1b in the file name? Im trying to get the file name shorter
    Thanks,
    Kyle
    Quote Originally Posted by cyipher View Post
    Thanks,
    Kyle
    The controller code is always pre-pended to the log file name, that can't be changed.
    You can obviously rename the files once you transfer them back to the PC. Just interested in why you'd want the names shorter?
    Aug 2011
    Well my biggest problem with efilive, isn't a problem with efilive as much as it is my setup. I use efilive in a drag racing scenario, and my laptop is just a small net book. The problem I have is the battery life is not good, and the only way it'll last a full day of racing is to keep it plugged in most of the time. I used to carry a jump pack that had an inverter on it to charge my laptop in the car cause I know with other manufacturers unit they dont want you to charge your laptop from the source your logging. So thay was 30ish extra lbs of unsecured weight in the car I didn't want to have. So my solution was black box logging, the problem with black box logging is I have to pull the v2 box out and take it to my laptop which is changing in a nice air conditioned vehicle. Hey when its 90 out, standing under the hot sun isnt fun in a fire suit. So my solution to that is a flashair card from toshiba, it installs and acts like a standard sd card but it has a wireless access point in it so the v2 box never has to be unplugged. I have the wifi sd card and it works great, distance range is about 30 ft thru the car and a wall at my house. Going back to the issue now, the card only supports early dos type file naming structures, so ls1b0001 gets changed into an abbrivated name and while I can figure out which log is which It would be easier to see an abbrivated name.
    Kyle
    Hi Kyle,
    I see what you mean. The firmware is supposed to keep the file names in 8.3 format. I'll make sure it does that in the next update.
    I just took a look at the firmware, specifically at the FAT32 file system code and ther eis no provision for setting the short file name explicitly. Only the long file name is recorded in the FAT. I think it is left up to the application reading the files (i.e. your card's wireless interface) to convert from the long file name to the short file name. I'm not sure why the wireles card would not convert "LS1B0001.efi" into the exact same short file name since it follows the 8.3 format. It could be that because the FAT32 filesystem is compiled to *only* support long file names, that the wireless card assumes all file names are long file names and blindly converts them to 8.3 format even if they are already in 8.3 format.
    To check that, can you please rename one of the log files to use only 7 characters while it is on your PC, then use EFILive Explorer to copy that file from your PC to the wireless SD Card via FlashScan's USB connection. Then try to copy that file from FlashScan to the PC via the SD Card's wireless link. Does that work as you expected or does it still attempt to convert the file name?
    Jul 2007
    If you are logging to the SD card, you can just take that and not the whole V2. Set the V2 to auto detect the memeory type and it will switch between internal and SD card as needed. I do like the WiFi card though.
    Aug 2011
    Well shit! sorry to have wasted you time Paul, but appers that even the short names get abrivated. I guess its an attriute of the card, but either way if anyone wants to know the flashair card from toshiba work great in the efilive sd slot and range is 30+ ft.
    Never heard of this before, but this is a great find and I think will help some people!
  1. Help with log file please.
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2011, 07:19 AM
  2. Log file help.
    By aaronr in forum Gen IV V8 Specific
    Last Post: September 21st, 2010, 03:27 AM
  3. How to display names on DIC
    By LBZoom in forum General (Diesel)
    Last Post: April 15th, 2009, 11:30 AM
  4. Would someone be willing to look at a log file?
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: May 6th, 2007, 09:47 AM
