Has anyone ran the Racetronix (SMP) 160 lb/hr low impedance Injectors and got them to idle good with good a/f? If so could you post your tune or let me know what you have the minimum injector pulse width, default minimum pulse width, small pulse adjust, and what do you have the injector flow rate set to? Also what fuel pressure are you running. I am trying to get these injectors to work in a 2000 camaro with a custom OS3 and an Acceleronics VersaFueler driver box. I just can't get them to idle good with good a/f ratio.
