Results 1 to 9 of 9
Thread: 2014 gmc 5.3
    May 2014
    Default 2014 gmc 5.3
    Have been unable to read using autos elect for ecm nor unable to make a log file. Have loaded pics but without proper ecm can't go further. Used E92 and tc43 and was able to read but cannot log either standalone or pass through says unsupported. Any suggestions?
    Post any ECM or TCM files you were able to read.
    Post screenshots.
    Nov 2005
    If your files are unsupported, please either post screen shots as per Joe's suggestion or list your OS's.
    Based on that information, if they are already mapped I will be able to send you files to install for tuning support ahead of our next release.
    Cheers
    Cindy
    May 2014
    450 miles from truck at the moment. Have sent ecm reads to BlackBear but beyond that stuck. Just trying to move ahead and educate myself while away. Will try and post when I return.
    Nov 2005
    Quote Originally Posted by dkeven@gmail.com View Post
    If you have those read files with you, you can email them to me and I will check so at least when you return to the truck you will have an answer either way.
    cindy at efilive dot com
    Cheers
    Cindy
    May 2014
    Can forward email as far as posting on forum via tapatalk no clue how to accomplish phone wont recognize to copy.
    May 2014
    Default read files
    have not gotten a screen shot as I have been trying standalone logging with the v2 but here are what I read with the v2 E92.ctzT43.ctz Have gotten new config file from BB and will try and run log file tonight n way home 10:30 pm central
    May 2014
    Error $0185 cannot create log file or folder is where I am now. Tried posting reads but haven't made it through moderator yet. Using a configuration file sent me to configure v2 but now this latest error has me dead in the water again
    Nov 2005
    I've responded to your email. You now have updated calibration files to install on your PC.
    Your $0185 is a FlashScan V2 setup issue. Take the time to read this thread to setup your device. https://forum.efilive.com/showthread...2-from-scratch
    Cheers
    Cindy
  1. 2014 silverado
    By gypsy06vortecmax in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 13th, 2014, 04:22 AM
  2. Is Camaro 2014 V8 still E38?
    By horst in forum E37, E38 & E67 PFI ECM's
    Last Post: May 27th, 2014, 04:24 AM
  3. Are the 2014 trucks supported yet ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 15th, 2013, 04:13 PM
