Results 1 to 5 of 5
Thread: license transfer
    Aug 2013
    Default license transfer
    I have an 06 cummins In an excursion I used my fathers efilive to flash a good factory tune and turn off the anti theft thus using one of his licenses. About a week later I decided to purchase my own efilive hardware. Is there any way to transfer the license for the excursion from my fathers V2 to my V2?
    No, you must purchase a license for your V2.
    Nov 2005
    Erik is right, once a license is used, it cannot be reclaimed or moved. You will need to license the vehicle to your FlashScan device (if you purchased your V2 new, it would have shipped with 2 VIN licenses), or continue reflashing with your Father's V2.
    Cheers
    Cindy
    Senior Member djv86's Avatar
    Nov 2014
    Cindy if he licenses the ecm/pcm with his personal v2 is that ecm/pcm then licensed and can be tuned by both v2s at separate times as long as the tune isn't "locked" ?
    Nov 2005
    An ECM can be tuned by multiple FlashScan devices provided the ECM is not locked and licensing requirements are met.
    Cheers
    Cindy
  1. Bad ECM, license transfer?
    By vic in forum FlashScan V1
    Last Post: April 16th, 2013, 09:11 PM
  2. Transfer VIN license
    By ClarkFarmsDiesel in forum Purchase and Shipping
    Last Post: October 2nd, 2011, 06:37 PM
  3. Transfer case PID's
    By mysunnshine in forum General (Diesel)
    Last Post: November 22nd, 2010, 05:07 PM
  4. Transfer case PIDS ?
    By fire0021 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 14th, 2010, 02:20 PM
  5. Transfer case question
    By bekmwan in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 22nd, 2009, 08:28 AM
