Iv'e had some difficulty trying to utilize this program with a 160 Baud (C3) computer. I use this program a lot to do 8912 baud streams on my cars, written several definition files, found it a particularly user friendly interface. But, for the life of me I cannot get 160 baud to work! My cable is a moates unit, utilizing USB through a virtual com port, and that works flawlessly.
The details... 88 Pontiac Fiero GT V6, 1227170 ECM
The ALDL has no chatter, it sends the stream when a 10K resistance is in the diagnostic mode port, (or its shorted) so it requires no information to be sent to the ALDL, this seems to go contrary to what macro's attempt to do. The stream doesn't have a ID byte or a mode, and might not even have a checksum. So the question is, how do I set the definition file up so that it will look for the data being sent from the ALDL instead of the program trying to request it? I have never seen a good working definition for a 160 Baud system ("87_gmc_truck" doesn't seem to help much) so I have nothing to model my definition from. At this point I am wondering if this will even work. I did set the "ALDL Baud" to "160-C3" and put in the length of the stream (for a 160 baud) and it still doesn't seem to work.
